Picture Perfect Share your photography tips, techniques and prize captures here. |
#1 | ||||||
Barn Stall Owner #204
Gameroom Barn Bucks: $403724
I shot with an old Nikon FE for years until I got my digital point-and-shoot and film went out of style. Was really lamenting the good old days of film photography and all my lenses (from wide angle to micro-Nikkor to 210 Zoom to 400mm fixed to bellows) that I couldn't use anymore. Then I found a professional grade Nikon D200 on eBay for a couple of hundred that lets me meter through the lens and shoot in aperture priority with all my old Nikon lenses and I am back in old-timer photography heaven again! Loving it in South Dakota. No auto focus with those old lenses but that just makes it all the more fun for me. Tried using some of the amateur versions like the D4 or the D3200 series but they would not let me meter through the lens. Contacted a Nikon tech support person and they steered me to the older Nikons that metered through the lens.
Even posted a picture or two in another thread: https://www.thevettebarn.com/forums/o...ml#post1150692 Then discovered that there is a photography thread already. ![]() |
The Following 3 Users Say Thank You to Black95 For This Useful Post: |
#2 | ||||||
Barn Stall Owner #1991
Bantayan Kids '13 ![]()
I still have my FE, but when I go out shooting, I take a D200 and D7000. I don't know what you mean about the D4 being an amateur version.
#3 | |||||||
![]() Quote:
#4 | ||||||
No problem. You should get a vertical grip for the D200 if you haven't yet. 2 batteries go a long way to keeping you shooting.
The Following User Says Thank You to carlton_fritz For This Useful Post: |
#5 | ||||||
Goldilocks
Barn Stall Owner #905 Bantayan Kids '13,'15 ![]()
Gameroom Barn Bucks: $1009320
I had a grip on my 20D and it sucked. It gave me false battery levels for some reason. It was a known problem I found out AFTER I bought the damn thing.
#6 | ||||||
Only feature of my old FE that I miss is the ability to use a shutter release cable. I built a gun stock support for the FE and my 400 mm lens in my wood shop and I put a cable release in the trigger position for shooting about 30 years ago. It worked pretty good when I wasn't able to use a tripod. The D200 doesn't accept a cable release, so I haven't used my gun stock since. I haven't done the research, but do any of you know if there is another way of remotely operating the shutter?
#7 | |||||||
Barn Stall Owner #79
Gameroom Barn Bucks: $955
![]() Quote:
which protects the contacts when the terminal is not in use. The following accessories can be used (cable lengths are given in parentheses; all figures are approximate): ♦ MC-22 Remote Cord (1 m/3 ft. 3 in.): Remote shutter release with blue, yellow, and black terminals for connection to a remote shutter-triggering device, al- lowing control via sound or electronic signals. ♦ MC-30 Remote Cord (80 cm/2 ft. 7 in.): Remote shutter release; can be used to reduce camera shake or keep the shutter open during a time exposure. ♦ MC-36 Remote Cord (85 cm/2 ft. 9 in.): Remote shutter release; can be used to reduce camera shake or keep the shutter open during a time exposure. Equipped with back-lit control panel, shutter-release lock for use in bulb photography, and timer that beeps at one-second intervals. ♦ MC-21 Extension Cord (3 m/9 ft. 10 in.): Can be connected to MC-series 20, 22, 23, 25, 30, or 36. ♦ MC-23 Connecting Cord (40 cm/1 ft. 4 in.): Connects two cameras for simultaneous operation. ♦ MC-25 Adapter Cord (20 cm/8 in.): Ten-pin to two-pin adapter cord for connec- tion to devices with two-pin terminals, including the MW-2 radio control set, MT-2 intervalometer, and ML-2 modulite control set. ♦ MC-35 GPS Adapter Cord (35 cm/1 ft. 2 in.): Connects camera to compatible GPS devices via PC cable supplied by manufacturer of GPS device, allowing lati- tude, longitude, altitude, and UTC (Coordinated Universal Time) to be record- ed with photographs (96). ♦ ML-3 Modulite Control Set : Allows infrared remote control at ranges of up to 8 m (26 ft.) From Your Manual |
The Following User Says Thank You to Jobaka For This Useful Post: |
#8 | ||||||||
![]() Quote:
#9 | ||||||
Got a remote release today. liked it so much I am getting my son a wireless model.
The Following 2 Users Say Thank You to Black95 For This Useful Post: |
