#1 | ||||||
Gameroom Barn Bucks: $2001216
So, I tried to make it to a Corvette gathering tonight, but had to turn around and head home...
To describe the problem, there's a very loud "clunking/grinding" sound coming from the rear, when turning, either towards the right or left. I think only with a load on it, when coasting around a turn or driving straight no noticeable noise. But the car has side pipes so it really hard to hear.... Half shaft U joints? Drive shaft U joints? I limped home but made it.....The problem grew worse, the longer I drove, or as it got hotter??? Not sure if the joints are originals, with or without grease fittings....? |
#2 | ||||||
My thoughts....because the issuing is occuring when turning either way,I think it's safe to rule out the U joints and concentrate on the rear differential. What is the recommended weight of the fluid. GM fluids i understand are the best brand, and I have a friend with a few bottles of the old whale oil. I will get the car on the lift later today to check the stubs for movement/play.....
#3 | ||||||
Barn Stall Owner #1969
Barn Raising II,III NCM Supporter '12,'13,'14,'15,'17,'21 ![]()
Gameroom Barn Bucks: $132003
Sounds like it needs a diff fluid change and the posi additive. In experience, the additive cured the "clunk-bang" sound.
The Following User Says Thank You to RonC5 For This Useful Post: |
#4 | ||||||
Barn Stall Owner #114
Here’s the stuff Ron is talking about:
Take care, Steve |
The Following 2 Users Say Thank You to RatDog For This Useful Post: |
#5 | ||||||
If grinding on turns I would check the rear wheel bearings and the "slop" that may be in the differential stub shafts......and of course the U-joints... Wouldn't hurt to check the trailing arm bushings and strut rod bushings. Its possible (but not my first choice) is that the clutch plates in the differential are binding - so yes a fluid change with the friction modifier additive might be worthwhile; then go out and do some figure-8s in an empty parking lot and see what happens.
#6 | ||||||
Thanks guys!
I got the car up on the lift and after a thorough inspection, I discovered fluid leaking from the drain plug pretty badly…. Must have been a piss poor mechanic that didn’t completely tighten the bolt down…. Everything else looks good. A few U joints I found to have zert fittings so they aren’t originals. There is no excessive play in the stubs or arm bearings. I’ve ordered the 80/90 and have a friend donating the REAL additive. I’m now thinking I might be getting off easy with this one! A few days and I’ll be in the lot doing those figure 8’s! |
The Following 3 Users Say Thank You to Don Rickles For This Useful Post: |
#7 | ||||||
While you're under there it wouldn't hurt to look at the snubber bushing and retorque the differential bracket support bolts.....here are some specs for you.
#8 | ||||||
#9 | |||||||
![]() Quote:
Live well, SJW |
#10 | ||||||
I can't take credit for that list, somebody complied it years ago and like many things in my tech library I can't tell you who. However, I've had occassion to "beat" the values in the document against shop manuals several times and the settings recommended are spot on.
#11 | ||||||
I'm aware that at least a few torque specs changed a bit during the mid-year run, so it does make sense to cross-check most of them against the AIM and shop manuals. Thanks, Frank.
Live well, SJW |
#12 | ||||||
Quick follow up…. The fluid exchange worked like a charm! The best way to describe it now is, “silk”! It’s a completely new feel to the rear and handling overall. After the exchange and inspection of the chassis, I took it out to an empty parking lot, and made those infamous circle 8’s! Then hit the roads for a nice 35-45 minute drive to get it warmed up.
Smooth as silk! |
#13 | ||||||
I think you may have dodged an expensive bullet.
Take care, Steve |
#14 | ||||||
The Following 2 Users Say Thank You to SJW For This Useful Post: |
#15 | ||||||
I love a happy ending.
#16 | ||||||
Probably some kind of animal tissue.
Steve |
#17 | ||||||
#18 | ||||||
So that’s whale oil?
Take care, Steve |
#19 | ||||||
#20 | ||||||
