Member/User Comments & Suggestions Tell us what you would like to see here. What you like and what you don't like. |
12-08-2009, 4:54pm | #1 | ||||||
The Old Guy
Gameroom Barn Bucks: $804566
Blackberry Users take a look!
This app has been tested on ALL simulators for BlackBerrys with OS 4.5+ installed. (Pearl, Curve, Bold, Bold 2, Gemini, etc.. )
The current version is not supported for Storm / Storm 2, but a Storm version will be released once we have the major bugs out of this one. Current Hardware Tested Phones:
BlackBerry Install Use your BlackBerry browser to surf to: http://www.BerryBlab.com/beta/BerryBlab.jad Once installed: - Open the software - Press the "BlackBerry Key" and select "Add Forum" - Type in the full URL The Vette Barn Forum - A Community for Corvette Lovers - Powered by vBulletin to VBF. That should be it. VBF should be listed and you can now surf using your blackberry, natively. Use the "options" menu when you are viewing VBF to sign in. This software comes with an Update Check for your BlackBerry, so you should only need to install it once on your phone and it will check for Updates everytime you connect with it.
12-10-2009, 9:22pm | #2 | ||||||
Gameroom Barn Bucks: $802
Can't wait to get this for my storm! Thanks GB!
12-10-2009, 10:47pm | #3 | ||||||
Barn Stall Owner #83 Barn Raising II
Gameroom Barn Bucks: $1000140
OK, I'll bite - back in 10 min.
Blackberry Bold |
12-10-2009, 11:33pm | #4 | ||||||
1. Omit forward slash AFTER "/forums" or you will receive error 404.
2. Can login and read, cannot post yet from Blackberry. Still working on it, receiving "exclamation point" error symbol. |
12-10-2009, 11:40pm | #5 | ||||||
test from secure wi-fi net
12-11-2009, 12:00am | #6 | ||||||
Tried 4 uploads including a new test thread, only one uploaded.
Post above was when connected to my secure wi-fi home network. None of the attempts thru ATT Edge and ATT 3G succeeded. ALL received "!" in a box with OK under it. |
12-12-2009, 10:19pm | #7 | ||||||
Charter Member - Vendor
Gameroom Barn Bucks: $155
gonna check this out
