#21 | ||||||
Barn Stall Owner #118
Gameroom Barn Bucks: $1002672
#22 | ||||||
![]() ![]() Not so much, as there are no windows. Lack of natural light depresses me severely. I spend a lot of time in the "third garage", under the rear porch where the Spider will be stored. I re-used two old windows from a renovation and it faces nearly due South. |
#23 | ||||||
#24 | ||||||
#25 | ||||||
#26 | ||||||
#27 | ||||||
Yep. as a wannabe architect, I've long studied Capes, and have found two that, IMO, are proportionally perfect. One is wood sided, on Cape Cod. The other is brick in NW Winston-Salem.
Mine isn't perfect like those, but it's as close as I could get with my limited education. During the final stages of the original construction: |
#28 | ||||||
#29 | ||||||
Is that cedar shingle? How is that working out for you? One look at the trees should have given you a clue. Looks great Yaddy
![]() A cooper sulfate solution will help with your problem. ![]() |
#30 |
Stall Owner #1120.2520 ![]() Join Date: Feb 2010
#31 | |||||||
NCM Supporter '20,'21 ![]()
![]() Quote:
![]() And speaking of houses falling down, how is @z06psi 's place holding up? Didn't AF2 make a similar prediction a few years back? ![]() |
#32 | ||||||
Gameroom Barn Bucks: $29012
The Following User Says Thank You to Murray For This Useful Post: |
#33 | ||||||
Charter Member Barn Stall Owner #98 Barn Raising II,III,IV ![]()
so, I zoomed in on your diagram... now wish I hadn't.
What's up with dis ![]() ![]() |
#34 | ||||||
#35 | ||||||
His guy GTO is going to be jealous.
#36 | ||||||
Barn Stall Owner #116
Doesn't have a big thing ![]()
#37 | |||||||
![]() Quote:
I flipped that basement room around so that the closet is in the back of the house. It will house a riser for the radon removal pipe, which will then snake through the structure to vent through the backside of the roof, not visible from the street. |
#38 | ||||||
Current basement, sans Cruiser.
#39 | ||||||
Why would you put your generator pad on a slope? I'm guessing so it matches your porches that look like they are falling off.
#40 | |||||||
![]() Quote:
And where, exactly, do the porches look like they're falling off? Your YDS is far worse than most liberals' TDS. Seek help. |
