Old 05-31-2020, 5:51pm   #1
thecornerman
Points: 8,265, Level: 63
Activity: 1.2%
thecornerman's Avatar
Gameroom Barn Bucks: $3335
Default Oil pan gasket replacement
I had an oil leak from the right rear corner of the oil pan.
The oil pressure switch is dry, looking thru the access hole in the bell housing I can see just under the rear main and it is dry as well.
it looked like it was coming from the upside down T area of where the rear main plate meets the block.
I replaced both upper and lower oil pan gaskets and I now have a leak from that same right rear corner, although now it looks like it might be closer to the actual rear corner
I did put a bead of RTV in all 4 corners where the covers meet the block
When running I get a slow drip like it is being forced out from pressure. I put on a new PCV assembly from GM to eliminate any crankcase pressure.
Is there anything that I should have done other than clean and apply RTV?
Or is there a know issue with the rear main plate gasket?
Easier to redo the O.P. gasket then pull the trans/torque tube assembly
And thoughts?
2002 Roadster
K&N Air Filter
Borla Exhaust
thecornerman is offline   Reply With Quote
