Old 04-28-2019, 9:34pm   #1
Geobsum
Points: 1,814, Level: 26
Activity: 0.8%
Geobsum's Avatar
Gameroom Barn Bucks: $540
Default Oil filter adapter seal installation
I have a 1987 vet that started leaking oil above the oil filter. I’m fairly certain it is a bad seal above the oil filter adapter and I found a replacement on line but am perplexed on how to remove the adapter. See photo attached. I was told that the nut unscrews but I can’t find a socket to fit and I’m wondering if it isn’t a nut but a pressed part of the adapter and whether the entire adapter unscrews after unhooking the oil lines. All input welcome.Name:  IMG_0445.JPG
Geobsum is offline   Reply With Quote
Old 04-28-2019, 9:48pm   #2
Lakeside49
Points: 6,646, Level: 56
Lakeside49's Avatar
Gameroom Barn Bucks: $1345
Maybe this will help get you going - looks fairly straightforward:
Good luck -
Dave
Lakeside49 is offline   Reply With Quote
Old 04-29-2019, 7:34am   #3
Geobsum
Activity: 0.8%
Geobsum's Avatar
Thx but I’ve seen this video before and it is an entirely different adapter with separate bolts!
I need to know how to remove mine since the nut(sides are bigger than any sockets that I can find) which makes me believe it is not a nut! If so how do I remove the adapter? Will a strap wrench work to turn the adapter once the oil lines are removed? Is there a special tool?
Old 04-29-2019, 11:33pm   #4
Lakeside49
Lakeside49's Avatar
I’ve Googled things a bit and agree that the instructions are elusive without a shop manual diagram.
Old 05-01-2019, 12:59pm   #5
Geobsum
Activity: 0.8%
Geobsum's Avatar
Finally was able to remove the adapter! Had to machine a 1 1/8 in socket flat to remove the slants on each face so I could grab the thin nut and crank it off! It comes apart and I attached photos so others can learn!Name:  IMG_0491.JPG
Size:  284.1 KBName:  IMG_0492.JPG
Size:  294.4 KBName:  IMG_0493.JPG
Old 05-01-2019, 1:02pm   #6
Geobsum
Activity: 0.8%
Geobsum's Avatar
Three photos showing socket befor and after
Old 05-01-2019, 1:03pm   #7
Geobsum
Activity: 0.8%
Geobsum's Avatar
Size:  195.6 KBName:  IMG_0495.JPG
Size:  202.2 KBName:  IMG_0496.JPG
Old 05-01-2019, 10:59pm   #8
Lakeside49
Lakeside49's Avatar
Sounds like you brilliantly figured it out. Impressive. I’ve learned from it. Not to own an ‘87! Seriously. How often should a 5.7L oil filter adapter enable or directly cause a leak?
Old 05-02-2019, 5:38am   #9
Geobsum
Activity: 0.8%
Geobsum's Avatar
Once in 32 years!
Old 05-02-2019, 11:23pm   #10
Lakeside49
Lakeside49's Avatar
No issues with my C3. Yet.
Now I have to go knock on wood.
But, I don’t even see them offered in the two C3 parts catalogs I get, so I’m hoping that is a good omen.
Good job getting to the bottom of it.
Old 06-04-2019, 10:05am   #11
Geobsum
Activity: 0.8%
Geobsum's Avatar
Now I need a new seal! Hunted for weeks with no luck! Seal is 3 3/8 in outside diameter! Anyone know where I can find one?
Old 07-25-2019, 7:11am   #12
Geobsum
Activity: 0.8%
Geobsum's Avatar
Took a regular oil filter and removed rubber gasket. Was a llittle too wide to fit oil cooler so I placed it on a plastic cup so it wouldn’t move around. Then used a Dremel high speed grinder to carefully narrow gasket to fit! Should work.Name:  IMG_0685.JPG
Size:  77.9 KBName:  IMG_0686.JPG
Size:  80.1 KBName:  IMG_0688.JPG
Old 05-14-2021, 4:18pm   #13
Geobsum
Activity: 0.8%
Geobsum's Avatar
Been there Done that!
Don’t repeat my mistakes
I machined a socket so it had no bevels
Removed the oil seal adapter and changed seal
At least 4 times because seals are impossible to get right fit
Tried gasket sealers
Still oil leak
Replaced oil temperature sensor which sits above oil filter assembly using several different sealants Still oil leak
Replaced gasket on rocker cover
Still leaked
Finally removed distributer cap and replaced oil pressure sensor which was leaking right out of space between ceramic and metal housing not where threads were
No more oil leak!!!!
The oil pressure sensor is likely your problem!!!
Start there
It sits on the passenger side slightly and the schematic drawings make it appear to be over there but when it leaks the oil runs down the driver side of the engine on top of the oil cooler adapter!
Good luck
