03-17-2024, 7:38am | #81 | ||||||
Gameroom Barn Bucks: $2001216
Change out the plastic oil pressure line with a brand new one. If this oil line was to snap off or brake while to motor is running, oil will shoot out everywhere! Don't ask how I know.....I'll tell ya....I had my car stripped to bare glass when I started the fresh motor, the line broke and oil sprayed all over the body.....had to clean it thoroughly......
03-17-2024, 1:47pm | #82 | |||||||
Barn Stall Owner #102
Gameroom Barn Bucks: $23243
03-17-2024, 1:48pm | #83 | ||||||
03-17-2024, 3:49pm | #84 | ||||||
Just sway bar links, probably one of the easiest tasks you have ahead of you
03-17-2024, 8:57pm | #85 | |||||||
Will source some. Wild they were left off. Getting correct steering column mount in this week so getting insulation on interior firewall now. Got dynamat installed today, I kind of enjoyed that. May have a friend of a friend coming to help workout wiring and mechanical stuff. |
03-18-2024, 5:21am | #86 | ||||||
Gameroom Barn Bucks: $1014987
Have you reached out to the Corvette club there in Ok city? If the members there are like the ones here then you will have all the help that you would need.
The Following 4 Users Say Thank You to Old Ben For This Useful Post: |
03-18-2024, 6:58am | #87 | |||||||
Most of the guys in the know were in their late 70's - 80's and ddn't get out much or offer to help, one guy offered me a silly low amount to buy the jag. |
03-18-2024, 7:09am | #88 | |||||||
Chairman Contact Person Rob Wilson 48384 [email protected] Vice-Chairman Flight Awards Administrator Kelly Bolton 20451 [email protected] Judging Chairman Judging Administrator Gene Holtz 10606 [email protected] Secretary Travis Firey 69877 [email protected] Membership Manager Membership Administrator Charles Buxton 48996 [email protected] Newsletter Editor Michael Aichele 11685 [email protected] Treasurer Scott Pfuehler 20940 [email protected] Webmaster Mike Partridge 60752 [email protected] National Corvette Restorers Society - Oklahoma Chapter Contact Information |
03-19-2024, 12:28pm | #89 | |||||||
Thank you. 😊 Emails sent |
03-19-2024, 12:33pm | #90 | ||||||
Correct steering column mount parts arrived last night so will get the old column back on this weekend.
Been pulling 12’s last 2 days so no work on car. I have a 3 day weekend so progress coming. Dynamat mostly done. Ran out and had to use up the rest of our killmat from the jag. Hubs OCD didn’t approve but will never be seen. 😛 Going to install heat barrier on inside of the firewall. Got the stuff from Lowe’s and making templates. Going to contact cement it up there any place I see the old jute/tar backed stuff was. Also plan to label some wiring. On the inside of the front, where headlights etc go, does that stay bare fiberglass or is it painted black like the engine bay? |
03-19-2024, 2:58pm | #91 | |||||||
Putting the column in is more complicated than bolting it up. You have to make sure the steering gear is centered (raise the front end) and the steering wheel is clocked to drive straight forward. This may involve rotating the rag joint a spline or twenty. Hang the wire harness and duct work into position rather than supporting with the column. |
03-19-2024, 4:40pm | #92 | |||||||
Great advice. Hubs has been wanting to make sure everything lines up. Will hold off on final install till drivers dash/ etc all in for sure! |
03-19-2024, 4:56pm | #93 | |||||||
There is tons of adjustment on the position of the lower bracket which attaches to the column. Probably 1.25" front-back and 1.25" left-right. |
03-19-2024, 7:42pm | #94 | |||||||
03-19-2024, 9:03pm | #95 | ||||||
I love steak and Manhattan’s, but an old fashioned will do. Unfortunately I’m busy that day. Lol.
I thought we were friends. Friends don’t ask friends to install a C3 interior. I’ll blather on about how I would do it as long as you will listen. Feel free to tell me to stfu when you figure out that what worked for me might not work for you. |
03-20-2024, 7:15am | #96 | ||||||
What do your patients say when they see grease under your fingernails?
03-20-2024, 8:22am | #97 | ||||||||
Busy eh? Blather on. Thing is, you ask and you'll get 20 "differing" answers. Guess we go with the most common, best reasonable response. Researching best order to do it. ID and labeling wires/plug ins comes first, since NOTHING was labeled as I did not take it out/off. Quote:
We cannot have artificial nails or even painted nails per hospital rules so they are short and boring anyway. Rule went into effect after a baby died from infection they traced back to nurses nails. I don't mind longer nails for a special event or evening out, but I do too many projects to have them on the regular anyway. |
03-23-2024, 9:41pm | #98 | ||||||
As I told Jim earlier.
A car guy came by and said we should get rid of the quadrajet and put in edelbrock carb and add petronix ignition Another person recommended HEI. Another person said just get someone that knows timing and get it set up to run correctly. So many opinions. 😵*💫 Quadrajet currently in the vette. |
03-23-2024, 9:47pm | #99 | ||||||
There’s nothing wrong with a Quadrajet carb if it’s set up properly. Just have to find someone (probably old) who knows how to do that.
The Following 2 Users Say Thank You to Steve_R For This Useful Post: |
03-23-2024, 10:25pm | #100 | |||||||
Fantasy Football Champ '12
Gameroom Barn Bucks: $90918
Lars Grimsrud out of CO is the guy to get a hold of, or at least his paper on how to set up QJ carbs. My 72 ran like a scalded cat after Lars tuned it up. |
