C3 Open Discussion General and technical C3 Corvette discussion - ownership, maintenance, repairs, modifications, restoration |
11-28-2018, 9:01pm | #1 | ||||||
1974 Vette and 1977 Vette fuel tanks
Need to know if the fuel tank from a 74 will fit in a 77 Vette minus sending unit and filler neck or what the dimensions are for both tanks
11-28-2018, 11:12pm | #2 | ||||||
Barn Stall Owner #16A
Gameroom Barn Bucks: $602908
Hi Chris- call Ekler's tomorrow. Their online website shows a different kit for the two years you mentioned.
They may be able to tell you if the tank itself will swap. My bet is that it will. I changed the tank out myself in my '76. Get new antisqueak pads- the old ones will likely be worn out and damaged. I remember the tank did not just slip right in- it needed some convincing. But it did eventually go in. |
11-28-2018, 11:13pm | #3 | ||||||
This website is primarily active in the Off Topic section. I'll cross post over there to see if someone else knows the answer.
11-29-2018, 8:34am | #4 | ||||||
Dimensionally they are probably the same. I believe that 74 tanks have the sending unit on the bottom and in 75 or 76 they re-located it to the top of the tank.
11-29-2018, 8:56am | #5 | ||||||
@Mechchris19 IIRC It's on the top for 76. It's been 20 years since I did it.
