11-03-2023, 2:17pm | #1 | ||||||
1967 Rear Leaf spring (replaced)
My 67 L68 rear (original) leaf sping looks brand new (cleaned, new pads, and painted gray).
I have had to purchase new non stock strut rod bolts (5" lg) for the car sit level My qustion is: This winter I will be removing the diff and trans, should I have the main leaf of spring re-curved? It looks almost flat when the car sits on the ground, has some arch but not much Do not want to go fiberglass |
11-03-2023, 2:50pm | #2 | |||||||
Barn Stall Owner #121
ride? I would leave your springs alone ,if the ride is good. |
11-03-2023, 2:55pm | #3 | ||||||
11-03-2023, 4:55pm | #4 | ||||||
11-06-2023, 9:52am | #5 | ||||||
11-06-2023, 3:24pm | #6 | |||||||
peace of mind. No I dont see the need to recurve the spring. Short or long as long as you have enough bolt thread to level your car, you are ok. |
11-06-2023, 3:39pm | #7 | ||||||
Previous screen name on Corvette Forum was 68hemi See my albums by clicking on my screen name for info and pictures of my cars. My vehicles are driven DAILY 1965 Rally red/black leather coupe with stealth 383 appears like a factory 365 h.p. engine 1966 Nassau blue/blue L72 convertible 1972 El Camino SS Silver/black 2011 Polaris RZR 900 |
11-06-2023, 3:52pm | #8 | ||||||
You guys are missing my point, with stock length bolts the car "squats" so I put in 5" long grade 8 bolts and now the car sits level. I replace the bushing also.
The spring "looks fine" but something has to be wrong where the stock length bolts won't work. My guess the spring is weak, so should I have it re "curved"? or buy new? (its the original BB spring with 45,000 miles on it) |
11-06-2023, 6:02pm | #9 | ||||||
Just buy a new one. Local spring shops should have the original specs
The Following User Says Thank You to AUTOHOLIC For This Useful Post: |
11-24-2023, 5:29pm | #10 | ||||||
If you are convinced you need a new spring look into Eaton Springs - and be leery of re'arching, it is a big deal....it requires heat and annealing the springs and ain't cheap if done right. Personally, if you have the car sitting level I'd leave it be; read the attachment for the process of re-arching.
05-03-2024, 8:45am | #11 | ||||||
Update: I purchased a spring from Eaton (was a pain in the butt to disassemble and paint gray) car now sits perfectly level with the correct length trailing arm bolts with castle nuts, ride is smooth.
Only grip is I had to re use my other spring's liners because the one on the new Eaton spring did not stick out enough Question, I removed the two outer bands (when I took the spring apart for painting). Do I re install them or toss them? my other spring did not have them |
