04-23-2024, 1:27pm | #2741 | |||||||
C4 Mod
Easy solution... I tint my windows. Crazy idea, but amazingly enough, I've never been burned by a seat. I certainly wouldn't drive around with a hideous ass white interior because of it. I'm struggling to think of something worse than a white leather interior. |
04-23-2024, 2:21pm | #2742 | |||||||
04-24-2024, 12:57pm | #2743 | ||||||
Why EV Mandates Will Not Happen in 2035
ETA: Maybe @Rob can make this a sticky so we'll remember to check back in 2035 to see if the mandates happened or not. |
04-24-2024, 1:42pm | #2744 | ||||||
Funny how things have changed in the last couple years. Used to be you couldn’t get a Tesla owner to shut up about Elon. Now all I hear from them is how much they hate him.
Finally saw a video of an EV owner who was truthful about range, and the numbers regurgitated by everyone are based on bullshit (EPA “rated” range multiplied by state of charge %) and the top 20%/bottom 10% of the battery is worthless on a long trip. 250 mile reported range ends up being 150 mile actual. |
04-24-2024, 2:58pm | #2745 | |||||||
On a 100% charge showing 330 mile range, I can go 250 miles at 80 mph unless most of it is uphill. However, around town, I can go 350 miles on a charge. My commute is 90% highway BUT traffic is slow most days which helps efficiency. I average 250 wh/mile on my morning commute. EPA is like 280 wh/mile. |
04-24-2024, 3:53pm | #2746 | |||||||
C4 Mod
On completely flat ground, you really can't drive for more than 3 hours from a 100% charge on the highway without an extended stop? Holy hell. |
04-24-2024, 4:30pm | #2747 | ||||||
My 2015 GMC gets 65 mpg.
If I travel downhill, in neutral, and have an 80mph tailwind. Otherwise, it gets 13mpg. |
04-24-2024, 5:05pm | #2748 | |||||||
Barn Stall Owner #116
Doesn't have a big thing
I hate shady car manufacturers!! |
04-24-2024, 6:59pm | #2749 | |||||||
Hot fast food meals make it worth the inconvenience. |
04-24-2024, 7:59pm | #2750 | ||||||
Rarely drove more than like 270 miles with my gas cars either. Can't go longer than that without a bathroom break anyways and breaks are good to avoid driver fatigue. On a 1000 mile trip in a day.. 250 miles then breakfast, 250 miles, then lunch and then another 250 miles than dinner and 250 miles to destination. With ideal charger spacing, only 3 stops in 1000 miles needed. We eat 3 meals per day. Works out perfect.
04-24-2024, 8:03pm | #2751 | ||||||
Then all the other car makers need to be honest about mpg too. Drive a Vette all day in NYC during summer with the AC on full blast and see if you get the advertised mpg
04-24-2024, 9:36pm | #2752 | |||||||||
C4 Mod
If you can't drive for more than 3 hours without having to take an hour long piss break, you need to stay off the roads all together. Quote:
250 miles - Breakfast. 250 miles - Lunch (~3 hours later) 250 miles - Dinner (~3 hours later) So just to clarify, for it to "work out perfectly" as you claim, you eat all 3 of your meals in a day within 6 hours of each other. There is no way you can spin it with hot meals or any of the other nonsense that you claim in defense of your beloved Elon. Having to make 3 extended stops in 1000 miles is f-ing pathetic. |
04-24-2024, 9:38pm | #2753 | |||||||
C4 Mod
Of the 5 cycles that make up the testing, 2 are as follows: The “A/C” cycle is very similar to the standard city cycle but at 95-degree heat with the vehicle’s air conditioning and the "cold FTP" cycle is exactly the same as the city cycle but run at 20 degrees with the heat on. You're welcome. I wonder why EVs don't have a highway range listed separately. They get away with a single combined mileage. Could it be that nobody wants to have to advertise that the range goes to shit at the time that most people need it the most? When they're on the highway? Nah, that couldn't be it. |
04-24-2024, 10:06pm | #2754 | ||||||
I have an idea for these charging stations.....add video poker and slot machines to the charging areas, so the customers have something to do to wile away the time while they're having their cars charging. Add a separate area for arcade games for the kids. Or hey, maybe just bring back Stuckey's rest stop restaurants?
Obviously the gambling machines would only work in states with legalized gambling, so Texas would be out, unless the charging stations were located on Indian reservations. |
04-25-2024, 7:39am | #2755 | |||||||
Ever heard of cities?? I mean, unless you drive through Nevada or Arizona, you will drive through a few larger cities if you drive all day and you won't be able to go anywhere close to 80 mph. So, realistically, if you go 80mph wherever you an, 250 miles will take closer to 4 hours on most major routes. 9 AM breakfast, 1 PM lunch, 5 pm dinner.. Works out great. |
04-25-2024, 7:46am | #2756 | |||||||
Anyways, a C7 Vette is rated 17 mpg in the city. I will bet you $$$ that if you drive a C7 in summer around Manhattan all day long with AC set below 70 degrees until you run out of gas, you won't get anywhere close to 17 mpg. So, complaining that an EV gets less range on the Highway than advertised is like complaining that gas cars don't get their advertised mpg/range in the city. Again, EPA does their rating based on 55% city and that's not car maker's fault that it's rated that way. BTW, their "HIGHWAY" cycle does not exceed 60 mph.. Also not car makers fault that the EPA rates that way. https://nepis.epa.gov/Exe/ZyNET.exe/...kPage=x&ZyPURL |
04-25-2024, 7:49am | #2757 | |||||||
Before I ripped apart my engine, after a failed water pump, I would get 30+mpg on highway in eco mode at 1,600 rpm at 70 mph in 7th gear.. My C6 also got close to 30 mpg on highway in 6th gear at 65 mph in 6th gear. Please point out any of the big three that have overstated MPG, as I know of none. |
04-25-2024, 7:51am | #2758 | |||||||
I wonder if anyone with a Vette will take a bet.. Let's meet up in Manhattan on a 95 degree summer day and fill up the car in the early morning and then drive around Manhattan with AC set to 68 degrees until you run out of fuel. If you get the advertised CITY mpg, I pay you $2000. I did own C3's, C4's, C5's and C6's... and none of them would get advertised city mpg if you are all day in city stop and go traffic with the AC on. Yes, on the highway, I could get 30 mpg but they sucked in the city. |
04-25-2024, 8:01am | #2759 | |||||||
I can also show you proof that I get less than 6 MPG on my current C7Z set-up on e85, and it does not affect my driving habits. If you care about your MPG I would NEVER recommend a sports car, as even though it can deliver the stated MPG, the driving disciplines to achieve such are not why you buy a sports car. Next we will talk about tire treadwear?? I have NEVER gotton close to 50% of the advertised treadwear, which does not bother me. I bought my last five vehicles knowing that MPG, treadwear and maintenance costs were meant for others, not me, as was not a consideration for me. Lastly, I would be much more concerned with coolant and oils temps while driving in city traffice, as paying for a little more gas is nothing compared to having an overheating event. |
The Following User Says Thank You to Onebadcad For This Useful Post: |
04-25-2024, 8:13am | #2760 | |||||||
Holy Hell you can be obtuse. EPA city ratings aren't based on driving around Manhattan on a 95 degree day with the AC at 68. That's not "city driving" for most people, nor is it what the EPA uses to determine city gas mileage. Quit making shit up. My average gas mileage in my C7 since I bought it 10 years ago is just under 30 mpg. That's combined city and highway driving. |
